Deletes a Flow Monitor key.
key | Specifies the Flow Monitor key. |
key_name | Specifies the assigned name of the Flow Monitor key. Range is 32 characters. |
N/A.
If a key has been added to a group and the delete command is used, the key is automatically deleted from the group. The related template key is disassociated and only deleted when there are no more keys or groups referencing it.
The system will reject any attempt to delete a key that does not already exist.
The following command deletes a key with the name 'src-ipv4-addr':
# delete flowmon key src-ipv4-addr
This command was first available in ExtremeXOS 32.2.
This command is available on ExtremeSwitching 5520, 5420, and 5720 series switches.
